ccie lab practise
Mar 19th, 2007
Dear,
I bought the 2511 router with 2x octal cable. Also i have 5 2600 router in my lab setup. I want to know to do the terminal server setup with the 2511 router to connect to the all routers and switches.
Thanks in advance
swamy
borek Mon, 03/19/2007 - 01:43
Well, as an CCIE candidate you should be able to setup terminal server in 5 minutes without consulting documentation!
Anyway, it's very simple, just plug the octal cable into console ports of the 2600 routers and configure desired login on each line. Something simple like this will do, if you are in secure environment and don't want to waste your time by entering passwords:
aaa-new model
aaa authentication login ccielab none
line 1
login authentication ccielab
exec-timeout 0 0
Borek
