CSS5-SSL-C-K9 compatibility with CSS11501 ?
Mar 19th, 2007
We requires CSS5-SSL-C-K9 (CSS11500 SSL Module w/ Compression ) module for our existing CSS11501 (Cisco 11501 Content Services Switch with Hard Disk and AC) engine. I have gone through all available documents of 11501 but can't find any SSL module slot either on chassis or on motherboard.
On the other way CSS11501S-C-K9 (Cisco 11501 CSS AC w/HD, SSL, Compression) comes with integrated SSL module so there is a possibility to upgrade 11501.
Please reply CSS5-SSL-C-K9 can be installed in CSS11501 or not?
Gilles Dufour Mon, 03/19/2007 - 02:56
no, it can't.
The 11501 is not modular.
You can't add or remove component/module.
Gilles.
