Catalyst 2948G-GE-TX
Mar 19th, 2007
hi all,
can anyone pls tell me the command to make anyother vlan as "native vlan" other than the default vlan 1 in catalyst 2948G-GE-TX switch.
cheerio,
Sathish
Amit Singh Mon, 03/19/2007 - 02:41
They way to do this is first configure the port to be a part of the VLAN that you need to configure as native vlan. For example if you want vlan 3 to be your native vlan and your trunk port is 1/2, then do the following
Set vlan 3 1/2, this will set tthe port 1/2 to vlan 3.
Then configure the port as trunk port and the vlan 3 will become native vlan on trunk 1/2
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/7_5/config/e_trunk.htm
HTH,Please rate if it does.
-amit singh
set trunk 1/2 on dot1q
-amit singh
