VG248 registeration with CCM
Mar 19th, 2007
I have connected vg248 across wan and tried to register it with CCM. I have enabled the DHCP option on VG248 and could not get the ip address assigned to it. I have other phones on the same subnet and they could register and get DN. IP help-address is configured and could ping the CCM and also from CCM to VG248 Connected voice ethernet subinterface.
Also, Auto registeration is enabled on CCM and tried adding manually via last 10 digits of MAC address as vg248 gateway.
Any ideas.
br,
shahid
Rob Huffman Mon, 03/19/2007 - 06:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Shahid,
The VG must be added manually, it will not Auto-Register. Here is the info assigning a Static IP etc;
Assigning a Static IP Address
Rather than using DHCP to obtain an IP address, you can assign a static IP address to the VG248. You can also change any of these settings even if you are using DHCP in your network. To assign a static IP address, you must manually assign several network settings
Set the IP Address
Set the Subnet Mask
Set the Default Router
Set the DNS Server
Set the Domain Name
From this good doc;
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_configuration_guide_chapter09186a0080235152.html#wp1041444
Hope this helps!
Rob
shahid.ikram Mon, 03/19/2007 - 07:03
Thanks Rob, but tried with static IP address, there is no communication between ccm and vg248 as phone port is not registered.
Any ideas.
thanks
Rob Huffman Mon, 03/19/2007 - 07:24
  • Hall of Fame,
    Founding Member
Hi Shahid,
Have you tried adding a VG Phone via CCM and actually plugging in the phone and picking up the handset?
The VG Gateway itself will not show as Registered in CCM.
Rob
shahid.ikram Mon, 03/19/2007 - 07:27
Rob,
I did add VG Phones with DNs but their status is unknown. Also, just correction, you can have DHCP enabled on VG248. On DHCP server, you can make reservation with VG248 mac address so that each time it has the same IP address.
Any other thoughts,
cheers
shahid
Rob Huffman Mon, 03/19/2007 - 07:38
  • Hall of Fame,
    Founding Member
Hi Shahid,
Did you plug in and test the phone?
Rob
