Cisco 7911g - group listen feature
Mar 19th, 2007
I have a problem with a 7911g phone. I cannot use the group listen feature (european style)with my ccme 4.0. (It doesn't work, or I didn't find the right command...)
I tried with a CCM5, and everything worked fine.
So the phone is working, but I have to make it work with a ccme 4.0. Is there a special command to make it work?
kern.jerome Mon, 03/19/2007 - 04:13
I want to be able to use the group listen feature (European-style speakerphone using the handset and the chassis speaker together).
Paolo Bevilacqua Mon, 03/19/2007 - 13:37
No, with CME the "monitor" softkey just toggles between handset and speaker. It would be a nice to have feature.
charalambos.ioa... Wed, 04/09/2008 - 01:05
Hello Guys,
Another quick question.
Is this feature supported on 7931 phones? or just for 7906/11?
Paolo Bevilacqua Wed, 04/09/2008 - 02:19
On the 7931, you don't really need that. The full-duplex speakerphone is good enough to enable anyone in the same room to participate in a conversation.
danburnett Fri, 05/02/2008 - 08:11
I run into this feature fairly often on legacy systems. Customers use a 'listen-in' feature that allows them keep the handset active, while setting the speakerphone to 1 way monitor. This allows other people in the room to 'listen-in' on the phone conversation. On the CM it's the group listen function, but only supported on a couple of phones. Any ideas to have the same function on a higher end phone with a full duplex speaker phone?
