03-19-2007 04:59 AM
I have done a clonning of my active disk in Solaris 9. When I reboot with the cloned disk, some of the processes refuse to start.
Process= Tomcat
State = Administrator has shut down this server
Process= Apache
State = Never started
Process= TomcatMonitor
Process= DCRServer
Process= CMFOGSServer
Process= CampusOGSServer
I guess it has something to do with Tomcat. I have tried to stop and start the LMS daemon, unsuccessfully. If I reboot using the original disk, no problem at all. How is this possible? The second disk is a physical copy of the first.
Thanks.
Solved! Go to Solution.
03-19-2007 09:46 AM
The problem may very well be the permissions of the underlying mount points. Unmount the file system in which CiscoWorks is installed (e.g. /opt), and look at the permissions on the /opt directory:
# ls -ld /opt
They should be 0755. If not, change them, then remount /opt, and try dmgtd again. You may need to repeat this with your other file systems.
03-19-2007 08:56 AM
Were all file systems cloned? CiscoWorks requires data in /, /var, and /opt for proper operation.
You may find additional information about why Tomcat is not starting in /opt/CSCOpx/MDC/tomcat/logs/stdout.log.
03-19-2007 09:33 AM
The clonning is a low level copy of the whole disk using the Solaris9 tool 'lu' so all the bits in both disk are supposed to be exactly the same. Find below the output of the log.
#cat stdout.log
Error occurred during initialization of VM
java.lang.Error: Properties init: Could not determine current working directory.
Since I installed it on the disk 0, I guess there's some parameter related to disk 0 and now when it tries to start from the disk 1 some initial configuration is wrong since it corresponds to disk 0 and not 1. Maybe the disk name is part of the working directory? Some idea?.
03-19-2007 09:46 AM
# ls -ld /opt
03-20-2007 08:27 AM
Thanks for your support, that fixed the problem. I don't understand why the 'lu' tool the changed permissions.
