failover using spanning tree
Mar 19th, 2007
Hi all, im trying to failover my 2 asa's by using spanning tree, creating a loop between them, is this possible ?
Amit Singh Mon, 03/19/2007 - 05:15
Are you trying to set a LAN based fail-over or connecting the ASA's back-back using the LAN cable? Please let us know more on the design that you are trying to setup.
-amit singh
carl_townshend Mon, 03/19/2007 - 05:20
thanks for replying amit, basically I have 2 asa 5505, in transparent mode, I want 1 of them to be redudant, I dont think they support failover so I was going to create a loop somehow, so it blocks on of the lan ports, or is there another way ?
please help
carl_townshend Mon, 03/19/2007 - 06:39
I had a read and I Dont think this will help, can anyone help me out on this ?
Amit Singh Mon, 03/19/2007 - 07:20
Sorry for the information provided above, I have just realized the ASA5505 doesnot support fail-over on it. Let me know the lan connectivity design you are trying to set.
-amit singh
