800 series
Mar 19th, 2007
Does anyone know if 800 series routers support bgp and,if no, which are the protocols that are used. I have a couple of those routers and i thought that it would be good if i used them for practice. I'm open to any suggestion.
Overall Rating: 2.5 (2 ratings)
deigonza Mon, 03/19/2007 - 07:23
Hi, the answer is yes. These 800 series routers support BGP:
831, 836, 837, 871, 876, 877 and 878.
The minimum IOS required is Advanced IP services.
Please rate if this has answered your question.
PS. If you need a specific feature, you can check what Router and IOS support them by using the Feature Navigator tool:
agentlife Mon, 03/19/2007 - 07:43
This means that if the router does not have the particular feature (bgp), i need to set it up, via tftp or something?
