SFPs on 2960-8TC
Answered Question
Mar 19th, 2007
Does anyone have one of the new 2960 switches with a 100FX fiber SFP operational. I just got one of these, and found in the fine print that is does not support the GLC-GE-100FX, but the way it is worded, it sounds like it could possibly support the GLC-FE-100FX - but that would be doubtful. See the below text:
Table 3-1 lists the cable specifications for 1000BASE-X and 100BASE-X SFP modules available for the Catalyst 2960. Catalyst 2960 SFP ports can use both GLC-GE-100XX and GLC-FE-100XX SFP modules. However, the Catalyst 2960-8TC and Catalyst 2960G-8TC switches do not support the GLC-GE-100FX SFP module.
Correct Answer by Amit Singh about 10 years 2 months ago
Just checked it for you. GLC-FE-100FX (100BaseFX) is supported on 2960 compact switches. You can use it on the 2960-8 port model switch and you will be fine with it.The same module is also supported on 3560 compact model switches.
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
rduke Mon, 03/19/2007 - 07:33
The link you pointed to says this on the fifth Q+A so that is not correct and my question still stands - but thanks anyhow.
Q. What SFP transceivers are supported on the Cisco Catalyst 2960 Series?
A. Cisco Catalyst 2960 Series Switches support 1000BASE-SX, 1000BASE-BX, 1000BASE-LX/LH, 1000BASE-ZX, 1000BASE-T, coarse wavelength division multiplexing (CWDM), 100BASE-FX, 100BASE-LX10, and 100BASE-BX SFP transceivers. Note: GLC-T and
GLC-GE-100FX are not supported on the Cisco Catalyst 2960-8TC and Cisco Catalyst
2960G-8TC switches.
Amit Singh Mon, 03/19/2007 - 08:21
  • Cisco Employee,
I think I overlooked you question.Thanks for making me understanding it.I tried to look at the compatibility matrix for the 100MB SFP module sheet and the new 2960-8TC is not listed there.It has all the other 2960 modesl listed.
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_table09186a0080380847.html
I will again check it for you, just to make sure on the point and will let you know.
-amit singh
Correct Answer
Amit Singh Mon, 03/19/2007 - 08:40
  • Cisco Employee,
-amit singh
rduke Mon, 03/19/2007 - 10:23
I am ordering one for overnight delivery. -will post high marks if it works.
Randy
Amit Singh Mon, 03/19/2007 - 10:33
  • Cisco Employee,
Randy,
It will work on your switch and let me know if you have any issues with that.
-amit singh
rduke Wed, 03/21/2007 - 10:27
I got the new transceiver in yesterday, and it does in fact work on the new 2960-8TC.
I think it would be helpful if the documentation stated that the GLC-FE-100FX works in the new switch instead of implying that it works by saying the GLC-GE-100FX does not work.
In any case, my problems is solved. Thanks for checking into it.
Randy
