XML Applications for CCM 3.3.5
Mar 19th, 2007
Is there any XML App's for CCM 3.3.5? I know the more current versions from 4.X.X are available but what about the older versions? If there are some where they are located?
Thank You!
fred.s.mollenkopf Tue, 03/20/2007 - 08:51
  • Gold, 750 points or more
Bill,
There is a SDK for CCM 3.x. Here is the link. Login and then select CallManager - IP Phones SDK. You will then see links for the different versions. Additionally Berbee, Citrix, etc. should have applications for a 3.x environment, at least I know they did awhile back.
http://www.cisco.com/cgi-bin/dev_support/access_level/product_support
Please rate any helpful posts
Fred
