cristip Mon, 03/19/2007 - 09:23
Isn't Etherchannel a good solution for this ?
What do you want to connect with this ?
if it's switch to switch then STP is your answer. If not Etherchannel with teaming on the server side.
carl_townshend Mon, 03/19/2007 - 09:26
there will be 2 transparent firewalls connected, its like this switch A --firewall x 2 --switch B , Could I use flex links in this ?
cheers
Carl
mohmmad.imran Mon, 03/19/2007 - 09:34
we can configure the flex-link on 3550 switches to provide the backup to a layer 2 interface.
As you have firewall connected to the ports, I would suggest use flex-link with MAC address-table move update feature if this is not configured and port 1 goes down, port 2 starts forwarding traffic. However, for a short time, switch keeps forwarding traffic to port 1 which is down.
Mohmmad Imran
Amit Singh Mon, 03/19/2007 - 10:02
  • Cisco Employee,
Carl,
Flex links is supported on 3550's starting with 12.2(25)SE series.So you have to upgrade the IOS on the switch to support the flex link feature.
I havenot tried it using the firewalls as you are designing, but its worth try giving a shot.This might work. use only one switch and connect 2 firewalls to it and then configure one switch uplink to firewall 1 as the primary link and the other uplink as the secondry link.
I am attaching a brief topology diagram for your refrence. Try configuring your 3550 switch with the above toplogy and configuration.
HTH,Please rate if it does.
-amit singh
