BGP conditional advertisement with 2 local routers and 2 ISP
mrzepa
I have router A connecting to ISP A and router B connecting to ISP B.
I have 2 routers (prefixes) to be advertised.
Under normal conditions, I want to have prefix A advertised to ISP A only and prefix B advertised to ISP B only.
If router A or ISP A should fail, I want router B to advertise prefix A to ISP B (and vice versa).
I am receiving only a default route from both ISPs.
I can make this work if I had only 1 router using BGP conditional advertisement, but I can't figure out how to make it work with 2 routers. Any ideas?
12 Replies 12
walleyewiz
What are your network prefixes you would like to advertise? Let me know--this should be pretty simple to do.
I want to advertise 159.18.14.0/24 to ISP A and 159.18.27.0/24 to ISP B.
Harold Ritter
You simply need to use conditional advertisement on both routers.
on router A, use conditional advertisement for prefix B and make it a non-existant dependancy on a prefix received from ISP B.
host routerA
router bgp x
neighbor advertisement-map advertise non-existant non-exist
route-map advertise permit 10
match ip address 10
route-map non-exist permit 10
match ip address 20
match as-path 20
access-list 10 permit
access-list 20 permit
ip as-path access-list 20 permit ^$
on router B, use conditional advertisement for prefix A and make it a non-existant dependancy on a prefix received from ISP A.
host routerB
router bgp x
match ip address 10
match ip address 20
match as-path 20
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
The conditional advertisement command should really be:
neighbor advertise-map non-exist-map
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Also, that is assuming that you already have a network statement for prefix A on router A and a network statement for prefix B on router B.
Cheers,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks for the reply, this solution would work if I was getting a full BGP table from both ISPs, but I'm getting only a default route, prefix 0.0.0.0/0, this prefix will always exist as long as 1 of the ISPs is available.
The solution I suggested will work in your case as well.
on router A, conditional advertisement will be linked to a non-existant 0/0 from ISP B ASN and the opposite on router B.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
To do that I would have to have both of my routers talking to both ISPs. I was not planing on that, I can see that working.
Thanks!
I was going to suggest what hritter suggested. That should work.
You don't need to have both of your routers talking to both of your ISPs. You simply need to run iBGP between your two routers. That is probably what you do already, don't you.
Cheers,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Mark,
Harold is correct. This solution should work.
You have 2 conditions in the route-map, named non-exist, and both conditions will need to fail for the network to be advertised.
Sundar
I had this exact scenario except I wanted to use one circuit completely over another, rather than splitting up advertisements between two circuits. Still had two routers and each router had their defaults to the ISP. It took me a while to figure this out but it was mainly from a lack of understanding of BGP functionality.
