Call viewer Duration = 72 sec
Mar 19th, 2007
My Unity box is getting high CPU usage. The box is getting more calls than normal but there seems to be something going on.
When I check call viewer I see that about half on the calls coing in have a duration =1 sec. The time interval can be from 1 second to 70 seconds. These seem to be using up all of my VM ports. Any thoughts would be apprecaited. Thanks
MikeTomasko Mon, 03/19/2007 - 09:20
Have you tried running the Port Status Monitor to see what actually happing with the calls/ports?
