03-19-2007 08:57 AM - edited 03-05-2019 02:59 PM
We had a co-worker get fired and took the passwords with him. We have txt files of the config but need away to decrypt the level 5 password. I would just run through the password recovery reboot but we cannot take the switches out of production. Any ideas? I also have some dell 3448s that I need to do the same thing on.
Solved! Go to Solution.
03-19-2007 10:08 AM
Hi Matt,
There is no way around it. You have to reboot the switch. Please plan it on a weekends and do the neceesary recovery.
HTH,
-amit singh
03-19-2007 09:33 AM
In order to do the password recovery you have to reboot the switch. Please use the doc below for password recovery on 2950 switches.
HTH,Please rate if it does.
-amit singh
03-19-2007 09:35 AM
No way around it. Cannot reboot because of production. Will just have to wait until an off day.
03-19-2007 10:08 AM
Hi Matt,
HTH,
-amit singh
