IP source based Load balancing?
Mar 19th, 2007
Hi all;
We encounter the following issue:
A load balancer directs requests in a round robin mechanism to several servers. We want the load balancer direct requests based on the source IP addresses, so that the same host would be directed to the same server at each time it reaquests to be connected (reconnection). Is this possible when using CSM module knowing that NAT is implemented?
Overall Rating: 3 (2 ratings)
g.degoeij Tue, 03/20/2007 - 05:15
Yes this is possible doing
vserver VAPP
virtual tcp 2514
serverfarm SAPP
sticky 90 group 8
idle 5400
persistent rebalance
sticky 8 netmask address source timeout 90
This should make the session sticky
