Printing from Historical Reports to network printers
Mar 19th, 2007
IPCCX 401sr1 Build 055
When user prints from historical reports, they can only print to locally attach printer - meaning the printer is attach to their PC. They cannot print to network printers. We tried setting default printer to several different network printers and no work.
Is hist reporting only for locally attach printer or can it print to network printers?
lpezj Mon, 03/19/2007 - 09:56
I think that there is no problem trying to print the reports in a network printer.
When you try to print the reports the application selects the printer that you have set up as default in Windows.
Hope this helps,
Juan Luis
aamercado Mon, 03/19/2007 - 20:27
Called TAC and I was hitting a bug. I had to add the network printer as a local printer by using the ip address of the network printer as a workaround. Thx
abdul ilyas Thu, 11/05/2009 - 07:57
Try this.
1. From the workstation that hosts the Historical Reporting Client, open C:\Program Files\Cisco CRS Historical Reports\hrcConfig.ini.
2. Once the hrConfig.ini file opens, locate (usually the bottom line) and set the flag 'UseSharedMemory=1'. Save and close the file.
Note: Set UseSharedMemory to1 to use the Shared Memory model and 0 not to use the Shared Memory model (default).
3. Reboot the workstation.
4. Print to the network printers from this workstation to test.
