03-19-2007 10:06 AM - edited 03-03-2019 04:13 PM
Guys quick question do you know what version of Sup720 supports OER?
thanks
03-19-2007 10:24 AM
Sup720 doesnot support OER.
http://www.cisco.com/en/US/netsol/ns471/netqa0900aecd800f5584.html
You can alo find the same information using the Cisco Feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
We are due with a new software release on Cat6500 and 7600 which will support OER.
HTH,
-amit singh
03-19-2007 10:33 AM
thanks, on their presentation last March 2005 they said it will be available on Catalyst 6500 and Cisco 7600 I guess they still working on it.
Thanks for confirming
Y
03-19-2007 11:05 AM
As I said the release is due in few months.I would suggest you to check the same here on forum again and we will keep you posted on the same.
-amit singh
03-19-2007 11:12 AM
-amit singh
03-20-2007 06:52 AM
Amit,
According to the 12.2SR Release notes, OER is now available in 12.2(33)SRB.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122relnt/122srrn.htm
