03-19-2007 10:33 AM
I will be migrating our VPN endpoint from PIX 515E to new ASA 5510 (7.2) Some of the VPN clients have version 3.x client software that currenly works ok on the PIX. I am trying to find out if they will be able to connect to the ASA with this version or not. They are remote and not in the office very much. Could someone point me to a link of supported ASA client software?
Solved! Go to Solution.
03-20-2007 03:13 AM
ASA supports the IPSec client versions that were supported by concentrator/PIX .
It will work with client version 3.x.
-Kanishka
03-21-2007 07:15 AM
Here is an image of the ASDM stating that it definitly does support VPN Client 3.x or higher:
http://www.cisco.com/univercd/illus/1/11/153911.jpg
Please rate if the post helps!
03-20-2007 03:13 AM
-Kanishka
03-21-2007 07:15 AM
