Remote Access VPN using Cisco 3005
Mar 19th, 2007
We have a 3005 VPN Concentrator terminating all of our remote access VPNs. One of the internal domain controllers went down which serves as DHCP/DNS servers for remote access VPN users. I changed the settings in numerous locations within the Concentrator configuration which has the new servers but users are still unable to connect. It gets stuck on "Negotiating Security Policy". I have confirmed from the VPN log that users are being authenticated properly. The log shows:
"Connection terminated for peer mblanchfield.
Reason: Peer Terminate, Administratively Disconnected."
"DHCP discover timeout: no response from polled servers"
"Received unsupported transaction mode attribute: 5"
Kamal Malhotra Mon, 03/19/2007 - 11:22
  • Cisco Employee,
Hi Mark,
Please make sure that when you goto Configuration | System | Address Management | Assignment, 'Use DHCP' is checked. When you goto Configuration | System | Servers | DHCP, you have the correct DHCP IP. Please also make sure that this server is pingable from the concentrator.
HTH,
Please rate if it helps,
Kamal
mark.blanchfield Mon, 03/19/2007 - 11:38
Kamal,
Hi. Thanks for the response. The servers are correct and I can ping the DHCP server. The logs are vague as far as what this might be. Here is more output from the log:
367 03/19/2007 13:28:14.770 SEV=6 IKE/201 RPT=4 66.153.244.7
Group [WaveL!nk1] User [mblanchfield]
Duplicate Phase 2 packet detected. No last packet to retransmit.
369 03/19/2007 13:28:20.280 SEV=5 IKE/50 RPT=2 66.153.244.7
Remote Proxy N/A, Local Proxy N/A
373 03/19/2007 13:28:22.560 SEV=3 DHCPDBG/39 RPT=2
DHCP discover timeout: no response from polled servers (xid 2251547051)
374 03/19/2007 13:28:22.560 SEV=5 IP/43 RPT=2
Deleting TCP entry for device 66.153.244.7 on port 18387
mark.blanchfield Mon, 03/19/2007 - 12:25
The issue is resolved. I had the incorrect DHCP servers in there. When I changed them, it started working. Thanks.
