Dot1q trunk across a vlan
Mar 19th, 2007
Hi all,
Currently, I am trying to design a network with 1) internet access, and 2) a point to point link with another location. My ISP is going to handle the point to point and internet connection over wireless equipment (the new building is in a non-servicable area). From my understanding, they're going to bring a dot1q trunk with 2 vlans into the building with the wireless, 1 vlan for internet, and the other for point to point. However, I have 2 vlans that I need access to at both locations (voice and data). Is it possible to bring in the trunk from the ISP to a catalyst 3560, split the vlans off, and then create another trunk into the point to point vlan? If so, how would I manage this?
paolo bevilacqua Mon, 03/19/2007 - 12:55
  • Hall of Fame,
    Founding Member
Yes, you can do that. The problem would be prioritization on the wireless link. Make sure the ISP will prioritize traffic marked EF and you should be OK.
