Warning message
choppy traffic on E1 Link
Mar 19th, 2007
Hi...
We have 2 sites 2610XM routers connected to each other via G.703 E1 controllers. The ISP provides us with 2MB E1 (unchannelized) links.
For some reason the customer wants to bridge the connection to use the same subnet in the 2 sites.
The configuration was done and I created a BVI for each router. This was successfully tested in the lab by connecting the 2 routers directly via crossed E1 BNC cables.
The problem appeared when each router was conneted in the sites. The connection is very waek with bad response times and missing pings (sometimes 2,3 out of 4 pings). I am able to telnet to the remote router but the session is very choppy with lots of delays. I didnt find errors in the E1 counters, although there are some interface resets.
Is it safe to conclude that the issue is probably faulty cabling, perhaps the ISP fiber backbone? Can a configuration error cause such behaviour?
Overall Rating: 4 (1 ratings)
paolo bevilacqua Mon, 03/19/2007 - 13:26
  • Hall of Fame,
    Founding Member
I wold conclude anything, can you post show controller ?
mo shea Mon, 03/19/2007 - 13:34
I will post the configs and other output once I get back to office.
mo shea Mon, 03/19/2007 - 20:50
Hi...
I am posting the config of one router (the other is the same) and sho controller output.
This router has 2 E1s, the one in question is E1 0/0 (the bridged one).
paolo bevilacqua Tue, 03/20/2007 - 03:58
  • Hall of Fame,
    Founding Member
the circuit on E1 0/0 seems to be fine.
If you want to clear your doubt about the bridging configuration causing the problem, change it for test to regular routing, and do a sweep ping (ping ip , y to extended options, fill values for minimum and maximum).
Hope this helps, if so please rate post!
