Cisco 2610 and FXO card
Mar 19th, 2007
I have CM working with 2610 and an FXO card. Everything seems to be working fine except that I don't have caller ID. I've found documentation saying that I need to enter "caller-id" command on the voice port, but this command doesn't exist for me. Is this an IOS version issue? Can someone tell me which feature set I should have for this?
-Shikamaru
aramos17428 Mon, 03/19/2007 - 18:03
I assumed the voice port is configured for MGCP, if this is the case then you will need to configure the gateway as H.323 to get caller-id working for the FXO.
Armando
shikamarunara Mon, 03/19/2007 - 20:29
Yes, it is currently configured for MGCP. Thanks for the tip, Armando. Much obliged.
-Shikamaru
