Wireless connectivity problem
Mar 19th, 2007
Hi Ahmed,
I am here again asking you to troubleshoot my connection.
Adsl is working perfectly, just I can not connect with my laptop, I mean it does not detect the SSID (Cisco) alredy configured on the 857w router.
Here I have attached the config, maybe you can take a look on it and see what is wrong.
Thanks in advance.
Daniel
jcorrale Mon, 03/19/2007 - 15:10
Daniel,
Try adding the command "vlan 1" under the ssid Cisco:
ssid Cisco
vlan 1
And also, try to add the following command under the global config mode:
Router(config)# bridge 1 protocol ieee
Hope it helps!
Juan
supergrip7 Tue, 03/20/2007 - 03:11
Just to let you know that I am still can not connect with my laptop to my 857w router wireless connection.
Thanks in advance.
Daniel
paolo bevilacqua Tue, 03/20/2007 - 03:43
  • Hall of Fame,
    Founding Member
I've seen this happening with 85x..
I think I had to erase configuration and start again, very strange. Will check a configuration that I have working later on.
jcorrale Tue, 03/20/2007 - 05:08
Hi Daniel,
Can you try this configuration:
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 128bit 0 1234567890ABCDEF1234567890 transmit-key
encryption vlan 1 mode wep mandatory
ssid Cisco
vlan 1
authentication open
authentication shared
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
bridge 1 route ip
I have that configuration working in my Lab with an XP Laptop.
Hope it helps!
Juan
supergrip7 Tue, 03/20/2007 - 07:56
Hi Juan,
I have tried your configuration and unfortunally my wifi is still not working.
Let me attached my config, meybe to have the change to see what is wrong on it.
Thanks in advance.
Daniel.
jcorrale Tue, 03/20/2007 - 08:35
Hi Daniel,
Try changing the encryption mode to WEA instead of "ciphers tkip":
no encryption mode ciphers tkip
Make sure that you choose WEA on your Laptop and add the 128bit-key "1234567890ABCDEF1234567890".
Also, make sure you choose WPA as authentication method and to use the correct key. You can also try to use the WiFi without authentication for testing purposes:
SSID Cisco
no authentication key-management wpa
no wpa-psk
Finally, remove the following line from the main Dot11Radio0 interface:
no bridge-group 1
Let me know how it goes.
Juan
supergrip7 Tue, 03/20/2007 - 09:32
Hi JUan,
Just to let you hnow that when I try to include the following line:
Error: key management does not support key index 1
Also when I try to include this one:
Error: Encryption mode cipher is not configured.
I am not a router expert...
Thanks for your support.
Daniel
jcorrale Tue, 03/20/2007 - 10:02
Daniel,
I'm going to recreate your issue in my lab. I'll give you the results as soon as I finish.
Juan
jcorrale Tue, 03/20/2007 - 10:12
Daniel,
I did the following changes to the last configuration you sent me and it worked on my XP Laptop:
no bridge-group 1
encryption vlan 1 Mode ciphers tkip
Here is the configuration I'm using:
no ip address
encryption vlan 1 mode ciphers tkip
ssid Cisco
vlan 1
authentication open
guest-mode
wpa-psk ascii 0 cisco123
channel 2462
station-role root
no cdp enable
no cdp enable
bridge-group 1
bridge-group 1 port-protected
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip access-group 102 in
ip nat inside
bridge 1 route ip
Juan
supergrip7 Tue, 03/20/2007 - 14:56
Juan,
I have changed my configuration as following:
int Dot11Radio0
no ip address
no bridge-group 1
write memory
Then if I go to (show running-config) looks like it did not save properly because just appear
no ip address
ssid Cisco
vlan 1
authentication open
guest-mode
Also let you know that I do have HP laptop with a PCMCIA SMC2632W wireless card, and it was working properly with my old 3com Wireless router, I mean it inmediatly detected the wifi connection.
I do not what is happening with my router existing conf, I attached it again, in just in case you can detect samething wrong.
Thanks a lot for your support.
Daniel
jcorrale Tue, 03/20/2007 - 22:07
Hi Daniel,
I noticed that you have two different SSIDs configured (Cisco and cisco). Lets do the following:
no SSID cisco
ssid Cisco
Now, if it doesn?t work after the changes, there should be something wrong with your Laptop configuration. Remember to change the WPA password/key on your Laptop to "cisco123" when connection to SSID "Cisco".
Hope it helps!
Juan
