troubleshoot fxo
Mar 19th, 2007
Every few days the vic-2fxo card in my 1751v router seems to stop working properly. It does not answer calls coming in but appears to try and place outbound calls. Only it doesn't seem to pickup the line. i.e. no dialtone, ringing tone etc. but the system seems to think the call is going through.
A show voice port summary shows the port is off-hook and operational status as up but it's not placing the call.
Any ideas? Any suggestions on debugging this some more? I'm sure it a faulty fxo but it's strange thatit only happens every few days.
paolo bevilacqua Mon, 03/19/2007 - 16:01
  • Hall of Fame,
    Founding Member
can be a stuck call. Status should be dorm, on-hook.
Can you check IOS and upgrade ?
The alternative is configure disconnection supervision (not always an easy task).
anthonyfear Mon, 03/19/2007 - 16:06
status was dorm, on-hook
However I tried shutdown on voice port and then no shutdown to bring it back up but now show voice port summary shows that status os dorm and on-hook but operational status is down. How do I bring operational status back up?
IOS is 12.4(11)T1
anthonyfear Mon, 03/19/2007 - 16:40
Thanks for you help
but that link is about disconnect problems - which isn't my issue. The ports work fine for a couple of days and then seem to fail for no reason. I'd like to find a way to debug so I can identify problem.
paolo bevilacqua Mon, 03/19/2007 - 16:53
  • Hall of Fame,
    Founding Member
Indeed, if you call from outside and hear ringback rather than busy, the port is not stuck off-hook. The debug command to see what the port is doing is "debug vpm signal".
aramos17428 Mon, 03/19/2007 - 18:00
Is the FXO signaling configured as Loop or Ground Start?
Armando
