IPCC Prompts
Mar 19th, 2007
I was just wondering if the prompts in IPCC Express need to be recorded in any certain way. Basically, the issue I am running into is that we hired some company to professionally record new prompts for us. They have sent us some sample wav files to test out and when I put them into a script just using the "play prompt" in a script, it does not play. I have debugged the script and the script does go to that step but just goes right on by never playing the prompt. I was just wondering if the prompts need to be recorded a certain way, or if anyone may have any ideas as to what would cause the prompt not to play and could shed some light I would appreciate it. Thanks in advance.
Overall Rating: 4 (2 ratings)
lpezj Tue, 03/20/2007 - 01:25
  • Gold, 750 points or more
If you are using G.711 codec you must have your wav prompts recorded in this way: CCITT u-law, 8Khz, 8 bit, Mono.
Ig you are using G.729, you will need any converter form your actual format to G.729, but the converters are not free, usually.
Hope this helps,
Juan Luis
p0ptart69 Tue, 03/20/2007 - 15:11
There is a installable G.729 converter on the Unity servers. You can install it in any windows box. Not sure what the lic conotations are but it works. Just do a search for 729 on the Unity box.
mpozorski Tue, 03/20/2007 - 20:36
Thank you for the heads up on that. I did a search and found the converter just to be safe. Thanks again.
mpozorski Tue, 03/20/2007 - 20:35
Juan - thank you very much for the pointers. It turns out that the prompts were not in the correct format so I used the windows sound application on the server to convert it to way you described and it worked like a charm. Thank you once again for your help.
