Dynamic Vlan with AP1231
Mar 19th, 2007
Hi experts.
I have this network:
- 01 AP 1231
- ACS v4.0
I try to config dynamic VLAN with LEAP.
SSID is WLAN map with vlan 1
Without attribute 64,65,81, I connect this WLAN ok and users alway is connected to vlan 1.
When I use attribute 64,65,81 and use
attribute 64 is vlan, attribute 65 is 802
user test1 has attribute 81 is 1
user test2 has attribute 81 is 2,
test1 connect WLAN successful (map to vlan 1) but test 2 can't authenticate successful with ACS Server.
I try to follow this link ( but not use Wireless LAN Controller ):
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
help me,plz
Tran Chung
amritpatek Fri, 03/23/2007 - 10:08
  • Silver, 250 points or more
IF it is authentication problem, then the problem is not with VLAN assignment. Because, VLAN assignment occurs only after authentication. So, send me the debug dot1x auth or debug dot1x aaa auth command output for verification.
magurwara Tue, 04/03/2007 - 17:58
Tran/Dmitri,
Is your switch port, where your AP connects to the wired network, configured as a trunk? You will need that in order to transport traffic to and from the VLAN other than the native VLAN.
Also, I have faced problems with dynamic VLAN assignment when multiple BSSID is configured on the AP. If your encryption settings are the same and you are using the same AAA servers, you will be better off using one SSID.
Trending Topics - Security & Network
