Possible to access own external IP's?
Mar 19th, 2007
When using a PIX 506 is there a way to allow the internal network to access the external IP range associated with the outside interface?
For example:
Web Server: 206.29.137.58
PIX e0: 206.29.137.57
PIX e1: 10.0.0.1
PC: 10.0.0.10
Is there a way to allow the PC to access the Web server using the external IP?
astripat Tue, 03/20/2007 - 13:24
Yes we can do that and the process used is referred to as "DNS Doctoring".
Here is how we can do it:
Create a static translation for the web server like this:
static(inside,outside) 206.29.137.58 dns
Here dns is a keyword.
Also, on the outside interface we should have an access-list which should allow access to this ip:
access-list 101 permit ip any host 206.29.137.58
access-group 101 in interface outside
I hope it helps.
Ashu
jksnook Tue, 03/20/2007 - 13:28
Thank you for the reply.
Does this mean that I would only be able to use DNS names to access the resources assigned to the external IP's? Or will I be able to use the direct IP address instead of a name?
Jason
