thisisshanky Mon, 03/19/2007 - 22:37
  • Purple, 4500 points or more
Cristian,
http://www.cisco.com/univercd/cc/td/doc/product/voice/srst/srst40/srs40spc.htm
SRST 4.0 does support 7941 but doesnt say anything about 7911. IOS versions that support SRST 4.0 are given below in this link.
http://www.cisco.com/univercd/cc/td/doc/product/voice/srst/srst40/srst40ad/srs_map.htm
Sankar
PS: please remember to rate posts!
cristian.munoz Fri, 03/23/2007 - 10:04
Hi Sankar
I upgraded the IOS and the IP Phone are registered, but for outgoing calls not works. I made a call using CSIM command and the call works. The router are connect to PSTN by E1 PRI.Pls. see the SRST config:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address port 2000
max-ephones 96
max-dn 120
access-code pri 9 direct-inward-dial
time-zone 11
date-format dd-mm-yy
This is the dial-peer for outgoing calls:
dial-peer voice 100 pots
destination-pattern 9
direct-inward-dial
port 0/0/0:15
