IP Phone lost there image after upgrading CCME
Mar 19th, 2007
I recently upgraded my CCME3.3 to 4.0(2)so that i can use the video conferencing features on my CCME. After upgrading CCME and IOS, most of the IP Phones lost there images and displaying an error "Protocol Application Invalid".
So i degrade back my CCME & IOS versions.Then again i loaded back the IP phone images.
What's is the problem? Is it i can able to upgrade CCME without having this problem?
Paolo Bevilacqua Tue, 03/20/2007 - 03:35
Possibly you need to upgrade the IP phone firmware also. What are you using now ?
Download the TAR file with DST fix from CCO. Extract to router flash with
archive tar /xtract
configure each file for download with:
tftp-server flash:/ alias
If your router doesn't support directories (that is, less than 28xx) just use
and load under telephony-service, without the .loads extension
Hope this helps, if so please rate post!
