Multiple Login Messages.
Mar 19th, 2007
I have a Cisco ASA firewall and when i login (only once) via "ASDM" console, i see multiple login attempts (login attempts with interval of 1 minute) in the firewall logs.
1. I want to know why this is happening.
2. How to fix this problem.
Looking forward for your help.
elliott.fougman Fri, 03/23/2007 - 03:40
In order to help diagnose this problem we would need to see the configuration file and the error message you are receiving.
suschoud Fri, 03/23/2007 - 07:28
the multiple login attempts which you see in syslogs in usual.
the asdm and asa exchange a lot of information while the attempt is made .
the various encapsulation algorithms are exchanged and a common one is negotiated to exchange the further info.
so,it's pretty normal.
no issues.
sushil Fri, 03/30/2007 - 03:20
Thanks for the reply.
It would be great if you could point to me some documents from Cisco reflecting the behaviour mentioned by you.
thanks in advance.
