ICM Monitoring Tools
Mar 20th, 2007
I have a customer who would like to load some third party monitoring software onto their ICM 7.0 NAM and CICM. The two tools they are looking at are Nimbus and ITM. can you advise whether or not these two tools are supported on the ICM platform.
Alex
Gergely Szabo Tue, 03/20/2007 - 02:22
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Before you install anything, check section 7.7.7 "Supported Third Party Software" here:
Hardware & System Software Spec. (Bill of Materials) for Cisco ICM/IPCC Enterprise & Hosted Editions, Releases 7.0(0) & 7.1(x) (PDF - 470 KB)
http://www.cisco.com/application/pdf/en/us/guest/products/ps1001/c1626/ccmigration_09186a00804d7607.pdf
I do not see the applications mentioned by you there...
You can, however, play with SNMP, it is there, by default (actually, it is required to install this service when setting ICM up)
