How to deactivate Unity voice mail
Answered Question
Mar 20th, 2007
I want that each user have the chance to deactivate his own voice mail.
Is it possible?. I use Unity 4.0.
Thanks.
Correct Answer by jbarcena about 9 years 11 months ago
I don't think that the user itself will be able to do this. You could just eliminate the Forward settings to VoiceMail but that can not be done from the CCMUser page (only CFwdALL), I guess that you could create an MLA user that will only have priviledge to change the phone settings in order to change the Forward rules in the CCMAdmin.
But at the end this is something that the Network Administrator should do not the final user itself.
//J
Overall Rating: 5 (1 ratings)
jbarcena Tue, 03/20/2007 - 05:59
What do you mean? What exactly do you want to accomplish?
What is the exact Unity version? 4.0(1), 4.0(3), 4.0(4), 4.0(5)...
carlostrapiello Tue, 03/20/2007 - 06:38
I want that user that don't want have voice mail running can deactivate it.
I use Unity 4.0(4)SR 1
Correct Answer
jbarcena Tue, 03/20/2007 - 06:50
//J
j-schulze Wed, 03/21/2007 - 10:05
If you want each indivdual user to control their voicemail settings(to forward no answer, busy, etc) I would suggest creating indivdual ccmuser accounts.
