about crash info files
Answered Question
Mar 20th, 2007
the flash memory of the router have some crashinfo files , even i deleted them from flash they are steal in flash. i think they are occupation the space because when i deleted them the free space doesn't increase
what can i do to clean the space from these files.
thank you
2 295738 crashinfo_19930301-001554 [deleted]
3 297439 crashinfo_19930301-000008 [deleted]
4 297438 crashinfo_19930301-000012
5 297439 crashinfo_19930301-000010
6 2276 conf1
7 1816 conf2 [deleted]
Correct Answer by jcorrale about 10 years 4 months ago
You can run the following command to delete the files completely from the flash memory:
Router#squeeze flash:
Hope it helps!
Juan
Overall Rating: 5 (1 ratings)
Correct Answer
jcorrale Tue, 03/20/2007 - 05:42
Hope it helps!
Juan
