Problem with db get in IVR 4.0
Mar 20th, 2007
HI,
I get this error when im using the db get step:
"File I/0 exception occurred, please select a db resource name first".
I have to tables created,Numbers and PIN.
The steps in the script are:
1. Db read, select * from numbers
2. Db Get from db resource name Numbers
3. Db read, select * from PIN
Until here it works fine, but then..
4. Db Get from db Resource name PIN
Here every time i choose properties for this step i get the error, i choose the bd resource name and apply, but the next time i get the same error.
It seems like i can have many db read steps in the script but only 1 db get step.
Anyone seen this before?
Gergely Szabo Tue, 03/20/2007 - 08:47
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
would you mind telling us what exactly you are trying to achieve with this?
As far as I see, you are trying to perform two SQL SELECT queries, from two different tables, right?
In those DB Get steps, are you associating the result column(s) to a local variable?
thx
