03-20-2007 05:49 AM - edited 03-03-2019 04:14 PM
I would like to know if the router can support 2MB. currently upgrading from 1MB to 2MB for cisco 1721 router. i am sure this can be done right?
Not need to upgrade to 1841 to cater to 2MB leased line right?
thanks!
Solved! Go to Solution.
03-20-2007 06:06 AM
Yes, the 1721 can support a leased line of 2Mb on an E1 circuit, xDSL, Frame Relay or any WAN link that supports 2Mb.
Hope it helps!
Juan
03-20-2007 06:05 AM
the 1721 should do it, but be aware that if many features are enabled, it may kind of suffer in CPU. The 1841 is much faster.
03-20-2007 06:06 AM
Hope it helps!
Juan
