CSM-S with Verisign (Test) Certificate
Mar 20th, 2007
I'm a SSL Newby, and I'm stuck installing a Verisign SSL Certificate on the CSM-S SSL Offloading Card. I generated the RSA Key pair, the trustpoint, I enrolled the cert. via the terminal method, then I copy/pasted the cert. to verisgn and I got a signd certificate back from them. Now they tell me that i have to install a intermediate certificate, how is that done? Do i also have to install a Root Certificate (and how is that done?)? Any help is welcome
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 03/20/2007 - 06:25
there is an example in the documentation @
Example of Three-Tier Certificate Authority Enrollment
In SSL software release 1.2, the SSL Services Module supports up to eight levels of certificate authority (one root certificate authority and up to seven subordinate certificate authorities). The following example shows how to configure three levels of certificate authority:
simonstoll Tue, 03/20/2007 - 08:42
Hi Gilles
You saved my day (no my week), thank you for your help, I got it working now! And I think, i even understand why :-)
Best regards
PS: Do you want a rating?
Gilles Dufour Wed, 03/21/2007 - 03:38
always rate if you can.
We don't do this for rating but it's good to see that the help was appreciated.
