VPN client to CISCO 857
Answered Question
Mar 20th, 2007
I would like to know if CISCO 857 allows remote software Cisco VPN clients aside from site to site VPN. I heard that all VPN cisco cable devices allow cisco VPN client software connections, is that true?
Thanks a lot for your help
Juan Manuel
Correct Answer by ggilbert about 9 years 10 months ago
Juan,
Allow me to explain a bit further to clarify some of the terminologies used which might cause confusion.
Cisco VPN router can terminate the following types of tunnels.
a. Lan to Lan tunnels
b. Dynamic Lan to Lan tunnels
c. VPN clients terminations
d. Easy VPN clients terminations
a & b, are very similar
c & d, are very similar
except - option c uses the VPN clients (software) installed on the PC or a MAC systems
Option d, uses hardware to connect to the IOS routers. You can use a Cisco Router or a PIX firewall or a 3002 or ASA to connect to the Cisco router which would be acting as an IOS Easy VPN server. And the device connecting to the Easy VPN server is called as a Easy VPN client.
Hope this explains the terminologies a bit more in detail.
To answer your question, Security Feature does allow support for Easy VPN client and server.
And what you are trying to accomplish is option c. So, the security feature option should work out well for you.
Hope this explains your queries.
Rate this post, if it helps!!
Gilbert
Overall Rating: 4 (1 ratings)
jmcandelera Wed, 03/21/2007 - 02:49
Hello Mr. Kamal,
I read the same document that you advice me a week ago, but I have no seen anything about Cisco VPN software client connections with respect to IOS software. Otherwhise, I read information about cisco 870:
http://www.cisco.com/en/US/customer/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
and in "security features" section appears support for: Cisco Easy VPN Client and Server (it is not in 850 features). I suppose that Easy VPN server feature will allow cisco remote client software vpn connections, won?t it? In that case, is Easy VPN server included in cisco IOS "advanced security"?
Thanks for your help
Juan Manuel
Correct Answer
ggilbert Wed, 03/21/2007 - 05:56
Juan,
Gilbert
