ASDM vulnerability concern
Answered Question
Mar 20th, 2007
Hello;
I'm contimplating on using ASDM as a tool to monitor my PIX 525 in terms of VPN trhoughput, interface stats and perform the security check, all of which the asdm program offers.
Currently I prefer to use the CLI to implement change, and I will continue this practive.
My question is "Should I be concerned if I enable http inside 192.168.1.0 255.255.255.0 so that I can access the installed asdm application?" Are there any security concerns? I'm thinking as long as I specify the host that will be used to access the PIX, I should be okay.
Your feedback is apreciated.
Jeff
Overall Rating: 5 (1 ratings)
abinjola Tue, 03/20/2007 - 10:35
  • Cisco Employee,
rather than making it for the entire subnet why dont you make it specific to few hosts..till the time you have your enable credentials safe..you are safe as well..:-)
jkrawczyk Tue, 03/20/2007 - 10:43
Hi, yes good idea.
Now I'm thinking will asdm use my tacacs service. If not, I need to find out how to configure.
Jeff
abinjola Tue, 03/20/2007 - 10:48
  • Cisco Employee,
you mean you have a TACACS Server configured ?..if yes then you can get ASDM authenticated via TACACS as well
jkrawczyk Tue, 03/20/2007 - 10:52
Yes I currently use tacacs server. Changed config is below:
I need to fond out if this config will use tacacs without any additional commands. I would think I would need to specify the authentication such as https. still digging on this issue. Thanks for the feedback,
aaa-server RADIUS protocol radius
aaa-server ABCACS protocol tacacs+
aaa-server ABCACS host 192.168.100.1
key guessme
aaa authentication ssh console ABCACS
aaa authentication enable console ABCACS
abinjola Tue, 03/20/2007 - 11:16
  • Cisco Employee,
add one more command for ASDM auth
aaa authentication http console ABACS
In this case you are not using the fall back mechanism that means if TACACS server is down ..then you would be completely locked
jkrawczyk Tue, 03/20/2007 - 12:13
Hi;
Currently if tacacs is down, my local account can be accessed via ssh or console by using the default ?pix? local account.
Are you saying if I include ?aaa authentication http console ABCACS?, I will not be able ssh into my PIX not even bby using the local ?pix? account? I?m a little confused. All configuration changes will be made from either my console or ssh session. ASDM will be used only for monitoring, but I want to authenticate with my tacacs server when I access my PIX via http as well as ssh and console.
Best Regards
Jeff
abinjola Tue, 03/20/2007 - 15:39
  • Cisco Employee,
yes you dont have a fallback configured that means that if your TACACS server is unreachable then you would not be able to access the firewall using ssh or console
to configure fallback to the local database try this :-
aaa authentication ssh console ABACS local
