Enabling ssh on router and denying telnet
Answered Question
Mar 20th, 2007
Here is my config:
line vty 0 4
privilege level 15
login local
rotary 2
transport input ssh
I thought since I specified ssh as the input transport that it would not allow telnet. What do I have to do to block telent. Also please explain the rotary group. Thanks,
Correct Answer by Richard Burts about 10 years 3 months ago
Matt
Given the config that you posted I would believe that telnet is not allowed on vty 0 4. Your message is not explicit about it but it seems to suggest that telnet is still working. Is that the case?
If telnet is still working then I would guess that your router has more than 5 vty lines (vty 0 4 includes 0, 1, 2, 3, and 4). Many of the current platforms and feature sets support more vty lines. On many of the platforms I am supporting the vty lines are 0 15 (which is 16 vty lines). The easy way to check is to show run and look down near the bottom. For historical reasons it will still show vty 0 4 and if there are more vty lines it will then show line vty 5 x (where x is the last line). If there are additional vty lines then include the transport intput ssh on them as well.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 03/20/2007 - 11:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Matt
Rick
matt.kurtzhals Tue, 03/20/2007 - 12:25
Right on Rick.
5 15 were also configured. Changed those and now telnet is blocked.
Matt
Richard Burts Tue, 03/20/2007 - 13:27
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Matt
Thank you for using the rating system to indicate that your problem was resolved. (and thanks for the rating) It makes the forum much more useful when people can read about a problem and can know that they will read a solution for their problem that worked. I encourage you to continue your participation in the forum.
Rick
