password recovery on 2600 doesn't work
Answered Question
Mar 20th, 2007
I'm trying to recover forgotten password on the 2600 router. I have been doing exactly as it written in the document however no luck.
this what i do
reboot into rommon > confreg 0X2142
reset
no on the promt
enable
copy startup-config running config
show running config
i have the folowwing at the end of the file
line con 0
exec-timeout 0 0
password xxx
login
transport input none
line aux 0
line vty 0 4
password xxx
login
conf t
enable secret test
no shutdown on each interface
config-register 0x2102
after restart i can't get into router
Please let me know what I'm doing wrong
thank you for your help
Correct Answer by sundar.palaniappan about 10 years 4 months ago
You changed the enable password but did not change the console password.
Perform password recovery again and set the line console password as follows.
line con 0
pass
Sundar
Overall Rating: 5 (2 ratings)
Correct Answer
sundar.palaniappan Tue, 03/20/2007 - 12:30
  • Green, 3000 points or more
line con 0
pass
Sundar
