NAC - LDAP Authenication Problem
Mar 20th, 2007
I have setup a NAC environment and have been able to authenicate to local defined user (Local Database). I setup a LDAP authenication server and have been able to authencate using the AUTH Test tab. When I attempt from the work station the local users are fine, but the LDAP based users get invalid username or password error message. The event log displays the following error "Unable to login, [00:12:3F:57:51:08 ##] testuser ". Both the local user and the LDAP server are assigned to the same role.
I'm I missing setting up a relationship for the LDAP authencation server to the CCA or login page.
oabduo983 Mon, 03/26/2007 - 12:01
Hi Dan,
When you enter the username and password, you should enter the Authentication provider name from the drop down menu. you should be able to configure this under the (user pages)
Please rate if this helps
