ITP 2600: SS7 Signalling Link to dest will not align
Mar 20th, 2007
I have a ITP 2600 and the link will not come up.
1) The point code is correct.
2) The SLC info is correct.
3) The E1 does not have any timing issues.
4) CRC4 is not active both sides
I have a few debugs running:
MBEBDITP2#SH DEBUG
CS7 MTP2 (Serial0/0:0):
Alignment Error Rate Monitor debugging is on
Congestion debugging is on
Error debugging is on
Initial Alignment Control debugging is on
Link State Control debugging is on
MSU trace debugging is on
MTP2-Layer3 debugging is on
Receive Control debugging is on
Retrieval debugging is on
Signal Unit Error Rate Monitor debugging is on
Errored Interval Monitor debugging is on
Timer debugging is on
Transmit Control debugging is on
DPC/Route status changes on all point-codes is on.
CS7 MTP3 (TMAR1LINK1):
MTP3 packet debugging is on
All SLM error debugging is on
All SRM error debugging is on
All STM error debugging is on
CS7 SCCP:
SCRC event debugging is on
SCRC error debugging is on
SCLC event debugging is on
SCLC error debugging is on
SCOC event debugging is on
SCOC error debugging is on
All SCMG event debugging is on
All SCMG error debugging is on
GTT event debugging is on
GTT error debugging is on
L3API event debugging is on
L3API error debugging is on
SUAAPI event debugging is on
SUAAPI error debugging is on
TCAPAPI event debugging is on
TCAPAPI error debugging is on
CS7-MONITOR event debugging is enabled
CS7-MONTIOR error debugging is enabled
I have even created a MTP2 profile adjusting the timers for timers T2-T7 but this has also not helped.
And what I can see in the debugs is that I do not get any response to the test messages FISU_MSU.
I have had a analyser on the E1 and this displays responses in the direction of the ITP but I cannot see them in my traces.
The customer has taken my word for it but I doubt the ITP 2600 a little bit....
I have even tried internally looping the E1 and the Serial interface to see if I could see the test msu response.....no joy
Could this be a know problem ???
Attached is my Show tech and debug
Please give me some tips.....my hair is failing out !!!!!......believe me baldness does not suit me !!!
bwalchez Mon, 03/26/2007 - 11:53
I think your problem is due to the host not being up at the time.
The way the system works is this The host comes up and opens the ethernet socket to the SS7 system. This then causes the SS7 system to open the socket to the VCO. If the host drops the socket to the SS7, then the SS7 likewise drops the socket to the VCO.
