PIX 506 - Limited Throughput ?
Mar 20th, 2007
I recently found a use for an old PIX 506 that I found in our store cupboard.
After doing a 'show ver' I noticed that although the number of internal hosts was unrestricted, the throughout is 'limited'. The outside ethernet is registering as 10/half.
Can anyone please tell me what the limitation is ? Is it just the difference between 10 and 100 Mbps ?
Rgrds
vitripat Tue, 03/20/2007 - 13:48
  • Gold, 750 points or more
You are right. PIX-506 will always be at limited throughput as it does not have a Fast ethernet interface. If you use a PIX-506E which comes with fastethernet interfaces, you'll get unlimited throughput.
Hope that answers your concern.
Vibhor.
dylan.webb Tue, 10/23/2012 - 16:59
Concerning the last post by Vibhor which appears to be incorrect as I have a PIX 506e here which is limited to 10Mb Full
as the below show ver indicates.
Hardware:   PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz
Flash E28F640J3 @ 0x300, 8MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0009.7c48.c0db, irq 10
1: ethernet1: address is 0009.7c48.c0dc, irq 11
Licensed Features:
Failover:           Disabled
VPN-DES:            Enabled
VPN-3DES:           Enabled
Maximum Interfaces: 2
Cut-through Proxy:  Enabled
Guards:             Enabled
URL-filtering:      Enabled
Inside Hosts:       Unlimited
Throughput:         Limited
IKE peers:          Unlimited
Is this a licensing limitation?
DGW
