IPCC express, Modify the historical report format
cjrchoi11
IPCC express 3.5(2).
How can I modify the historical report format such as title name via crystal report which available in the 'Reporting type'?
Another question is how generate the report which available in the 'Report template' directory? Do I need copy the files to a specific directoty to selectable in the report tool?
Thanks in advance,
tapk5
Level 3
Level 3
All reports are Crystal reports format, so open the report templates by Crystal, and edit title as you will. All report templates are under cisco historical reports>Report templates folder.
You need to add the new report into report catalog file with .xml.
Wei
tapk5
Level 3
Level 3
Wei
Thanks a lot Wei !!!
