Warning message
CSA agent on Call Manager with NIC teaming
Mar 20th, 2007
Has anyone install CSA agent on Call Manager with NIC teaming? Do I need to remove the NIC teaming, install CSA agent then put back NIC teaming. Do I select network SHIM during installation ?
Chris Deren Tue, 03/20/2007 - 20:41
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I've done it several times, it does not matter when you install CSA. Yes, select shim as that should be your only availabe selection.
Chris
