asa firewall access list
Mar 20th, 2007
Hi all, can anyone tell me why creating an access list allowing an ip subnet to another one through my firewall would not let me connect remotely to the pc, until I added the tcp port of the program in, I thought ip would of covered this ?
cheers
acomiskey Tue, 03/20/2007 - 18:47
It does not function that way, ip is all encompassing. For instance if I had...
access-list 100 permit ip any any
I would not need
access-list 100 permit tcp any any eq 3389
Post the acl's you were using. Are you sure you had the acl applied?
carl_townshend Wed, 03/21/2007 - 02:14
here are the acls, for some reason I have had to allow the port in to dial into the machine. It would not work without
access-list inside-vlan_access_in extended permit ip 172.16.0.0 255.255.0.0 any
access-list inside-vlan_access_in extended permit ip 172.24.0.0 255.255.0.0 any
access-list inside-vlan_access_in extended permit ip 172.23.0.0 255.255.0.0 any
access-list inside-vlan_access_in extended permit ip 172.17.0.0 255.255.0.0 any
