2nd Line Rings Constantly
tim.fulton
Is there any way to stop the 2nd line presentation from ringing constantly and have it instead only ring once or twice before muting itself. We're running CCM 4.2.
Rob Huffman
Hi Tim,
This can be changed on a line by line basis, have a look (in this instance maybe you would like the Ring Once option);
Device>Phone>Directory Number Configuration
Line Settings for this Device
Display (Internal Caller ID)
External Phone Number Mask
Line Text Label
Message Waiting Lamp Policy
**Ring Setting (Phone Idle) Use System Default, Disable, Flash Only, Ring Once, Ring
**Ring Setting (Phone Active) Use System Default, Disable, Flash Only, Ring Once, Ring
Hope this helps!
Rob
