unable to connect to internet
Mar 20th, 2007
I have a cisco 1721 with a WIC-1ENET want card connected to internet through DSL modem with static ip. (No pppoe)
I used SDM to configure the connection where as the connection works fine with a netgear router but after connecting to cisco 1721 and configuring its not working with the same ips.
When i test the connection through SDM , it errors out when testing exit interface and gives exit interface as none.
This is my running config on the router , some one please help me to resolve this issue.
Thanks in advance
Mohammed
! Last configuration change at 23:16:49 UTC Tue Mar 20 2007 by admin
version 12.3
hostname techxxxxxx
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1xxxxxxxxxxx
enable password xxxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip routing
ip name-server 71.xxx.xxx.xxx (DNS provided by ISP)
ip name-server 71.xxx.xxx.xxx (Secondry DNS provided by ISP)
no ip cef
ip audit po max-events 100
username admin privilege 15 password 0 xxxxxx
interface Ethernet0
description $ETH-WAN$
ip address 71.xxx.xxx.xxx 255.255.255.0
ip nat outside
no ip route-cache
half-duplex
interface FastEthernet0
description $ETH-LAN$
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip route-cache
speed auto
half-duplex
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 71.xxx.xxx.xxx (Default route provided by ISP)
ip http server
ip http authentication local
no ip http secure-server
access-list 1 remark INSIDE_IF=FastEthernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
snmp-server community public RO
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
ntp server 129.6.15.28 prefer
end
Overall Rating: 5 (1 ratings)
jcorrale Tue, 03/20/2007 - 22:11
Hi Mohammed,
I noticed that you have routing disable on your router "no ip routing", so the router doesn?t know how to route packets. Lets enable it as follows:
Router(config)# ip routing
Let me know if that works.
Juan
mcyclegar Wed, 03/21/2007 - 18:45
Thanks Juan
It worked and its so stupid that i missed it.
Thanks again for the help.
Mohammed
