MC3810 / sip-ua / ITSP ?
Mar 20th, 2007
I have a MC3810 with 12.3.18 which gives me access to the sip-ua command. Can I have this register with a sip proxy/itsp? I have seen references to commands available in the sip-ua context for authentication information ...etc however I do not have this available. Thoughts?
paolo bevilacqua Tue, 03/20/2007 - 19:45
  • Hall of Fame,
    Founding Member
do you have "authentication" as a command under "dial-peer voice xx pots" ? These are the credentials to register the number used as "destination-pattern" to the proxy configured as "registrar" under "sip-ua".
Hope this helps, if so please rate post!
Arthur Kant Wed, 03/21/2007 - 06:42
I will check on this and let you know but my first thought is no. I do know that I do not have a "registrar" under sip-ua . I do have a sip-server where I can specify an IP address but nothing that looks like authentication information. I will try and post a menu list.
paolo bevilacqua Wed, 03/21/2007 - 09:38
  • Hall of Fame,
    Founding Member
Most likely not because HTTP Digest authenticating for sip is a 12.3(8)T feature so if the 3810 can't run that you do not have it.
Arthur Kant Sun, 03/25/2007 - 13:13
Ok but I am running what I think is a newer version. I am running 12.3.18:
IOS (tm) MC3810 Software (MC3810-A2JSV5-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 15-Mar-06 21:46 by dchih
Image text-base: 0x00023000, data-base: 0x0185FC78
So let me make sure I am understanding. You are saying that I do not have a sip authentication feature on this IOS release which is best I can run on this router. However I should still be able to register with a sip proxy / location agent (ie Asterisk) so my fxs ports show up can be reach ed by that proxy?
Thanks!
paolo bevilacqua Sun, 03/25/2007 - 16:46
  • Hall of Fame,
    Founding Member
Hi, 12.3(18) is not newer than 12.3(8)T, because the latter is a T train image, that is, it contains new features while the mainline does not.
To use registration you need "registrar" under "sip-ua". If you can;t support registration the other SIP party must have configured you address statically.
