03-20-2007 07:29 PM
Hi, I am trying to enable XML over HTTPS on a CSM (WS-X6066-SLB-APC)with 4.2.5. When I go under XML-Config I do not see anywhere I could setup HTTPS. I would appreciate your help.
03-20-2007 09:33 PM
I havent tried it by myself. I would love to know if it works. Please try this
1. enable HTTPS on the Sup
use following link
2. Once HTTPS is enabled on SUP then you configure the xml-config in CSM.
Let us know if it work :)
Syed Iftekhar Ahmed
03-21-2007 04:20 AM
I do not see the IP http-secure server option on the SUP IOS, I only find IP http. Have you seen any Cisco document that would indicate that HTTPS is supported on a 6500-SUP720-MSFC3 IOS?
03-21-2007 02:24 PM
Bad news.
I double checked it and its confirmed that 'ip http secure-server' is not supported on the Sup720 platform.
Syed Iftekhar Ahmed
03-22-2007 02:20 AM
Thanks. I guess it is a feature that will be be available in the future.
Luis
